someone tell me how to hang a door straight.
Discussion in 'The Garage' started by colbystephens, Apr 20, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm getting pissed. how do i make the door hang straight?
  2. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    trial by error
    ive had to put shims in the bottom hangers before.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    did you take the door off the hinges or the hinges and door off the cab?
    The right way to do it is with the fender off. that way you can get to all the bolts while the door is closed. set the gaps and then put your fender back on and set the gaps on it to the door.
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    now that's a cool idea! i can't do it tho because my sliders are welded to the front clip tho...
    in anycase, the problem is actually that the PO cut out and welded the striker bolt back into the body in the wrong place... grrr..
  5. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    if thats the case I would be happy with it if it latched. I know how to set gaps but you should see my woods truck :rolleyes: you can stick your finger in the door to fender gap. I fixed it by taking the door off.:D
  6. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    After redoing my blue truck, I think the only way I would hang another door would be: to take the hinges off the cab, and hang the door on the wall. LOL gmc4cw said what I had to do, take the fender off. Then match the fender to the door, then to the hood, and the pillar. Gapping, and bondo I hate!
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    It's a lost art..... heavy collision is a crash course (pun intended)
    Colby, go hunt around the body shop, I've posted on this at least a dozen times...
  8. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I remember reading somewhere: Get it almost tight, close it, then even the gap around the door using a prybar and something to cushion it. I just bolted mine up loose, they bang into place. :D
