Someone tell me what I did
Discussion in 'The Garage' started by sapper, Jul 7, 2006.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Hopefully a simple fix, yesterday I was doing some battery work picked up some long battery post. long story short I went to crank it and the post were to long so the cables were not snug and something popped. Now it wont try to start, the battery is fine just not getting power anywhere. Any suggestions would be great.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Check the fusible links. Look for burnt insulation, and give them a tug (pull on em). If either is suspect, you just need to cut out the damaged section and splice in a new one. Should have the ratings written on the old ones, if you can't make it out, somebody here will know what size to run. I really can't help, cause I got rid of my fusible links a while ago.
    If I remember correctly, there should be one down at the starter, one at the alternator and a couple on the firewall.
  3. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    Well i would first go down and check your starter. if u blew the sylonide. you can jump the terminals on the starter and see if it still works. if thats fine id start checking ur ignition setup. im assuming you went through ur fuse box and checked all ur fuses.?
  4. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    X 2
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    Thanks guys
  6. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    cracked solenoid??
    If you tugged on the positive cable,you may have cracked the cap on the starter solenoid where the cable bolts on...if the fuse links blew,they are located in the smaller wires going to the post on the solenoid that the positive cable bolts too(they might be hidden inside a metal tube bolted to the bellhousing bolt near the exhaust manifold--there are two of them in two 10 ga. red wires..)..there is another fusible link (or 2)near the brake booster on the firewall ,and some trucks have one in the thick red wire going to the back of the alternator..:crazy:
