someone xplain thin&thick gears to me please
Discussion in 'The Garage' started by ilikeitloud, Dec 1, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    i was just wondering because i would like to regear here soon to 513s. i have a d60/14bff. i was under the impression that if you use thick gears you can reuse the same carrier thats used for the 410s that i have in there now am i right?? also am i able to get thick gears for the 60 and 14bff?? what are some good places to look online for R&Ps?? thanks much
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yes, "thick" gears allow you to use a 4.10 and down carrier for 5.13s.
    best prices I have found are on the vendor's forum on pirate4x4.com... tho tim may be able to hook it up as well.
    j
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Yes , you can reuse your old 4.10 carrier for your 14FF if you get the after market thick gear set .
    The material that R/P's are made out of is very high grade and fairly exspensive so axle manufactures sometimes made differentials with the ring gear mounting flange in different locations to avoid having excessive ring gear material. The after market addresses this issue by offering the thicker gears but the O.E.M.'s saved money by making seperate series carriers because they are making such large volumes of each - if they can save a few bucks on everyone that they build , in the long run it is more cost effective for them . The aftermarket makes money because there is a market for the thick gears when the correct carrier is hard to come by or the other series carrier is more plentyful.
    I can not remember if a "Thick" set of gears are offerd for the Dana 60 but a call to a gear seller will answer that for you.
    HTH, Tom
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    iirc the thick gears are only for the HP60 (Ford 60's) not GM and Dodge.
  5. stangfootball34
    stangfootball34 Registered Member
    Aug 21, 2002
    27
    So do I have to buy a whole new carrier for my dana 60 to run 5.13's or do they make a ring gear spacer or something. I run 4.10's as well in my dana 60.
  6. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I think atho is correct about the thick gears only being offered for the HP gear sets. There is a ring gear spacer available but it is a personal call if you want to use it or not . You might want to check with the person , or shop , that is going to do your gear install and see what there thoughts are on the spacers - not all gear installers will use them .
    On a lighter note; the higher ( numerically ) ratio Dana 60 carriers are fairly easy to find .
    Good luck , Tom
  7. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I have a dana 60 35 spline detroit locker for 4.56 and up ratios if you have a chevy 60. It'll take those steep gears without a spacer-you can find the standard thickness gears and save some of the cost back on the locker.
  8. stangfootball34
    Aug 21, 2002
    27
    How much do you want for that chevy dana 60 4.56 carrier with a detroit locker?
  9. stangfootball34
    Aug 21, 2002
    27
    How much do you want for that chevy dana 60 4.56 carrier with a detroit locker? And shipping to 75069 in Texas.
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    AFAIK you do... of course, if you got a detroit, it wouldn't be a problem since it replaces the carrier. I have a 4.56 and up + detroit in my chev 60.
    j
