Something is Grinding!! Any Ideas
Discussion in 'The Garage' started by babyburb, Nov 14, 2006.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I finally had the chance to get the new burb in some mud and something is grinding in the front D44. It sound to me like it is coming out of the diff but not sure.
    My question is, could this be somekind of locker the previous owner installed? I was told that some lockers make alot of noise when engaging?
    It did seem that it only started when my rear end began to loose traction. At this point, I did not have it in 4 wheel drive thought. Is a 76 burban an all wheel drive? I have noiced during hard turns I get tension in the steering like it is locked into 4.
    It is a 3/4 ton with d44 and 14bff?
    Any ideas or trouble shooting I can do?:confused:
    Thanks guys.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your burb's tcase is still the full time 203, check that your front driveshaft isn't binding to cause that noise, also check your front ujoints.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Also since its old , pull the front cover , if its fine in there you are changing the fluid and concentrating elsewhere ..... but missing teeth can make a grinding too , and a real bad bang sometimes messing the steering up or feeling like steering resistance .
  4. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    does it have locking hubs? what t-case?
  5. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    no locking hubs and I thought it was the 205 but might be a 203. I have to look after work.
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    depending on how much lift you have it may be the front driveshaft rubbing on the crossmember. mine did it with a 6 inch lift.
  7. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    np203
  8. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    no lift but new 33s with fender trimming
    plan on looking it over this weekend with the tips so far unless something else comes up
  9. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    I feel stupid! It was the fan hitting the fan shroud when the body would twist and motor torqued. Thanks for the help though.
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    been there done that, knew what it was though, heard it on other friends trucks.
    Kinda a crazy sound, time for new motor mounts :D
