something is wrong..
Discussion in 'The Garage' started by chvymudin3388, Mar 27, 2007.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    unbelievable hesitation till i put the pedal past like half throttle. and it seems like there is no power especialy in the lower rpms seems to have power in the higher rpms though. what could it be?
  2. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    well when my bro's did that it was a simple fuel filter problem.
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    is this a diesel isuzu?
  4. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    sry bout that i shoulda been a lil more specific on what it is :-\ 87 chevy blazer tbi fuel injected had bad gas in it recently think it coulda partially plugged the old fuel filter cause it seems to wanna start to backfire and stuff if held at wide open throttle to long driving down the road trying to pass someone
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Well, swap out the filter and get back to us. Remember, quite often we overlook the simple stuff when we have a problem. :deal:
  6. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well the filter was plugged but uhm nope it runs good in the higher rpms it shifts goes to low and bogs down gets higher runs great shifts again and bogs back down what is wrong???
  7. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    no body knows??? it seems to run better when its cold too
  8. Can Can
    15,552
    136
    Is it throwing any codes?
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i dont know how to read all that stuff plus i think my check engine light is burnt out
  10. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Check the plugs and other related items. Could be basic tune-up related.:dunno:
  11. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    Don't know about TBi, but my 75 did the exact same thing when the carb gasket went bad and I had a huge vacuum leak just below the carb. Might be something to check out.
  12. shockline
    shockline Registered Member
    May 10, 2006
    51
    Powhatan Virginia
    I had the same symptoms and it turned out to be clogged cat converter. If it smells funny under the truck thats a good sign. I thought mine was fuel, then maybe trans, it was only the cats
  13. Kp
    Kp 1/2 ton status
    Apr 5, 2006
    135
    Tucson
    I second the vacuum leak possibility.
  14. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    or you have a bad fuel pump...
  15. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well ive stripped the cat it was plugged changed plugs got the bad gas out changed fuel filter and it gots a brand new tbi gasket but it could be leaking
  16. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    a code reader is about $25. Deffinately worth it along with a $1 bulb to get an idea about what your motor is doing
  17. dyeager535
    26,980
    Code reader? OBD1 GM code reader is a paperclip. :)
  18. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i think my timing is way off but i dont see how its running with how far it appears to be off... idk ... the timing mark is on the other side of the motor when running and as far as i know it hasnt slipped cause 0 is still top dead center
  19. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    if your on the #1 plug wire then your 180 degrees out, i dont know if it is even possilble to drive like that. from what is seems it sounds like its running too hot. my big block is the same way. at about 180 degrees the throttle response and low end punch is good, once it warms up completely at about 210 (with 180 thremo.) it doenst run as good. pay close attention to your water temp gauge and flush your cooling system and get a new thermostat if it is getting hot. the reason i think it too hot is because you said it runs good cool.
    if its not that, i know some fuel enjected vehicles have a throttle position sensor (TPS) and if it is off, then everything is off; including fuel input, timing, etc.
    Mass air flow sensors also affect the way you engine runs with your characteristics, but again i dont know if you have one...
  20. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i wouldnt think itd run if it was 180 out though and its got like i think a 195 thermostat im putting my other 180 thermostat in it this weekend and i if that would be 180 out then why is the piston all the way up on number one when its at zero?
