something just isn't right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hpfire7227, Apr 19, 2000.
  1. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    something just isn\'t right
    what's up guys and gals. hoping somebody has a suggestion for me about this...it's getting me worried. While driving at about 40-50 mph is when it happens.It's like the engine skips, but it's a violent skip,that makes the whole truck rock and the drivetrain clunk. It usually just lets out one of these 'skips', but sometimes there will be a group of 3-5. It sounds very serious, and I'm stumped because other than that, it runs strong and smooth. Its an 89, 350 tbi. Also, it seems to do it frequently when there is a load placed on the engine, like going up slight hills...when it is about to kick in. Could it be a tranny or drivetrain prob.? Any help is appreciated!
    10 BOLTS O' FUN
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Re: something just isn\'t right
    If you have not done it, I would change the fuel filter first, sounds like a clogged filter.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  3. hpfire7227
    Mar 14, 2000
    75
    Holland Patent, NY
    that was my first thought too...just did the fuel filter with no results. FRUSTRATING!!
    10 BOLTS O' FUN
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yes I second that! Had a simmilar symptom! I swaped the fule pump and fuel filters and haven't had it sence!!!
    Rock ON![​IMG] 72 K5 [​IMG]
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    That sounds to me like the symptom of a lockup torque converter clutch going bad. If I am correct, very soon you will lose the ability to move the truck at all. The TCC will self destruct. When this happens, the truck will creep forward when you give it gas in a forward gear, but it will not hook up. I hope this is not what is wrong with your truck. Has your tranny been rebuilt? I am assuming it is an automatic. When the TCC does go, it will spread chunks of metal throughout your tranny, most likely requiring a rebuild.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Does it happen when the motor is hot or cold? If it happens when you're running warm, it might be the ignition module kicking out........ I sure hope for your sake it's not the TCC - it sure sounds messy!!!!!!
  7. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I doubt this is it, but here's my story. The power wire for my HEI was loose and kept loosing contact when I'd drive over bumps. The engine would kind of cut out for a split second and then come back on. Just something for you to check I guess.
    '73 K5
    Chevy good...Ford bad
  8. muddking
    muddking Newbie
    Apr 16, 2000
    3
    michigan
    Try disconecting the four prong plug for your torque convertor lock-up switch. if your problem goes away, than it is that switch. I won't affect the tranny but you will lose some MPG. Tranny may also run a little warmer. try the plug first.
  9. hpfire7227
    Mar 14, 2000
    75
    Holland Patent, NY
    Thanks for the input guys. Hey muddking, where is that switch? How accessible is it? Thanks again.
    10 BOLTS O' FUN
  10. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I agree that it's the TCC. I had a car that did the same thing, although much more violently than you described. The dash used to jump an inch about every half a second if I kept the speed constant. Scared the s*#t out of me the first time it started. I unplugged the TCC wire harness and that took care of it.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    Proud owner of an 88 Jimmy
  11. chad
    chad Registered Member
    96
    Minnesota
    I'm with Canmore, our Corsica did that and damned if I could figure it out. Took it to one of my dads friend's who is a mechanic he drove it a knew right away what the problem was, he changed the ignition module and bam worked like a charm!
    Cruisin Taz in a 79!
    Chad
  12. hpfire7227
    Mar 14, 2000
    75
    Holland Patent, NY
    ok then...I'll throw in a new ignition module and unplug the TCC harness and call you in the morning. Thanks again for the help.
    10 BOLTS O' FUN
