Something knocking on my floorpan?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MadIrish, Aug 27, 2001.
  1. MadIrish
    MadIrish Registered Member
    Aug 13, 2001
    48
    South Carolina
    Stange thing. As you may know, my drivetrain has some boogers in it. Here is another thing it does:
    I back down my drive way, put in D, give it a little gas, start moving then *knock knock*! It sounds like something near the tcase is knocking on the floorpan! Seems to happen as I am turning. Only happens once then it seems not to re-occur. Any ideas?
    *******82 K5 All stock but wheels and tires, 305 4bbl, tranny? NP208*******
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I had a loose body mount bolt that made that same noise.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    I have also heard loose body mounts do that. It seems to thump the floor from take off.
    Keep it simple!
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I currently (hope to fix this week) have the same noise. Mine is a bolt missing from my drivers side motor mount. When I get on the gas hard, the motor twists and the transmission "knocks" on the floorpan. Maybe you have the same thing?
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
  5. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Yeah, my freind had an S-10 that did that, was a bad rubber bushing I think.
    Four wheel drive, four wheel expenses...
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if it does it over bumps too i would say look at your upper shock mounts. this is why i dont have shocks in the back of my blazer anymore. they elongated and pulled out on a trip in cali
    body mount could be...
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  7. Grim-Reaper
    7,385
    Atlanta
    It\'s a Rice boy in the Honda you just backed over!
    I had a transfer case bolt drop out and it would do that every time I got on a hill where I had to gas it hard.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  8. MadIrish
    Aug 13, 2001
    48
    South Carolina
    Re: It\'s a Rice boy in the Honda you just backed over!
    Cool guys! I'll look into those as soon as I can!
  9. Me too !!
    I had the exact same problem a month ago and I had lost a bolt from the tranny/transfercase mount. LocTite fixed her right up !
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  10. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    im having a problem similar to what grim is describing. if im in 2wd and park with the front wheels hanging on the curb the truck makes a loud popping noise as it settles of the curb. i dont practice parking on curbs but when i noticed it i tried it again and the same effect. could it be a worn out t-case chain? i have a NP241
  11. dyeager535
    26,980
    Haha! Had the same noise. Scared the $hit out of me. Thought my tranny or t-case was shot. Make sure the speedo cable is held in place securely, and isn't near the floorpan where it can smack it when the cable moves inside.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  12. MadIrish
    Aug 13, 2001
    48
    South Carolina
    HEY! I do have a cable coming out of my tcase that is wearing the protectant off my floorpan as it hits it. It seems to come out of the front-side of the tcase and hangs about 2 inches from the pan. There are marks on the pan where it has obviously hit the pan a lot. Wonder if that's it?
