Something went wrong
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Nov 15, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I found out why my truck died on me the rotor and the dist cap had been torn apart and melted on the insde I replaced both of them and the spark plugs. But is i the coil that casued this to happen. If so what do I need to fix it. And if it wasnt the coil what could it have been then?
    1985 GMC JIMMY
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    One of our best co. mechanics once told me that if there's a problem with with your secondary igntion system(coil/ignition module, cap, rotor, wires, plugs), the best thing to do is to replace EVERYTHING at the same time.
    I'm still not sure if you have a coil or a module? Which one is it?
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Where do the wires go after they leave the coil on the dist cap?
    1985 GMC JIMMY
  4. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    how bad were the plugs? how bad are the wires? If these are to the point that the electricity cannot get through then the 20,000-40000 volts or whatever it is has nowhere to go and will melt your cap and rotor. It probably melted right were the rotor touches the cap...or no?
    Chris
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  5. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Yes it did The plugs were fouled so I changed them. The wires are good. The truck is running now but I wanna know if I have to change the coil or what happened to the coil in order to this to happen.
    1985 GMC JIMMY
