somethings not right with my T400
Discussion in 'The Garage' started by RustBucketRacing, Apr 6, 2003.
  1. RustBucketRacing
    RustBucketRacing Registered Member
    Nov 18, 2002
    13
    San Diego, Ca.
    This tranny has been in my blazer for about four years now and has worked great. Just in the last couple of days when I let off the trottle it seem like the tranny just lets go. Then when I get back into it the tranny seems to have to catch back up to itself. There is tranny fluid. Any suggestions.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Is it full though. I would change the filter and fluid and go from there.
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    What gear does this happen in!?
    All the gears? How does reverse seem- any different?
    Is this happening ALL the time now, or only once in a while like it could be the shifter linkage?
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  4. RustBucketRacing
    Nov 18, 2002
    13
    San Diego, Ca.
    Seems to be more in 2nd and 1st. Reverse seems fine. Fluid is full. tranny is working fine till I let off the gas and then it seems like the tranny just lets go.
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ah! Sounds like it just needs some new clutches and seals. Thats about all that goes down on 400's. Or it could be your torque convertor clutches are shot. But the good news is those 400's are cheap to work on and if that ain't cheap enough, they are not bad to rebuild either. Good Luck! /forums/images/graemlins/pimp1.gif
  6. Storm Trooper
    Nov 24, 2000
    4,640
    Dump the fluid & check for black material or metal in the pan. Does the fluid smell burnt?
    If the torque connveter is going it will take out the tranny quick. If the filter is plugged up it will also cook it quick.
