Somethings wrong help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyblzr1977, Sep 4, 2001.
  1. chvyblzr1977
    chvyblzr1977 Registered Member
    Jul 18, 2001
    83
    Pissburgh,pa
    I got a 77 blazer and i was driving it yesterday when i noticed there is this noise in the column when you turn it it kinda sounds like its grinding.I know its coming like right below the steering wheel anyone know what is causing this.My steering kinda feels loose.When you turn to the right then when you turn it to the left its gets stiff i have no clue whats causeing this any suggestions.
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    My 78 has a bearing in the column under the lockplate. Check to see if that is what is causing your noise. Mine doesnt seem bad, not sure how to change or if you can.
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I had this happen to my 84.
    You've got to pull the wheel. There's a little part in there that is out of place. I can't remember exactly what it was, but you'll know when you tear into it.
    Lift It, Lock It, LIVE IT!!!
