Sometimes smooth, sometimes HARD
Discussion in 'The Garage' started by bambamtama, Jan 7, 2004.
  1. bambamtama
    bambamtama Registered Member
    Nov 18, 2003
    21
    4-corners, Az
    hahaha, didn't mean to be so blunt with the Subject...but I need some sugestions.
    My 86' 383 chevy blazer is in the midst of being rebuilt. One of many problems I want to fix is the steering. It has Power Steering, but it's been weird. Every once in a great while the whole steering is working; the steering is smooth and it's not hard to steer. THEN at times on the same trip it was working smooth the steering starts to play and it's hard to steer! What is causing the mis-haps? /forums/images/graemlins/confused.gif
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Could be air in the system.
  3. bambamtama
    Nov 18, 2003
    21
    4-corners, Az
    thanks for the response, How do you get air out?
  4. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    jack the front of your rig up and with the engine turned off grab the front tire and turn it back and forth several times then drive it.
    this may take a couple of times but it will work the air out. /forums/images/graemlins/thumb.gif
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    does it become hard to steer after you have been wheeling it hard? if so, you may be overheating the PS fluid, a cooler may be needed. a lot of guys in our club run a tranny cooler in the PS system.
