SON OF A.........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Jul 12, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Somewhere down the road I seem to have smashed my t case crossmember and in doing so tweaked the hell outta my frame!!!! I'm hoping by raising it back where it was and pulling the bottom frame rail down again it will level the truck. The whole right side is sitting an inch or two lower than the left.
    Any thoughts or opinions on this? I'm guessing when I lowered the t case and put the spacers inbetween the x member and the frame it didn't support the frame enuff and it twisted. Im hoping I can fix this on my own. I remember landing hard on a rock wheeling awhile back, I'm guessing thats when I tweaked it all.
    I don't belong to a gym, I do MY situps and pushups under my blazer! http://community.webshots.com/user/blazerk5
    Jim
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    what a b!tch. i did the exact same thing. i hit a huge rock(boulder) and it tweaked the left side of my frame about 1/4" and messed my crossmeember. now i cant get into 4x and it has a vibe. luckily all i need is a new crossmember and i can bend the frame back with a huge crescent wrench. a frame shop quoted me $75. i think i can do it on my own for a hell of a lot cheaper. good luck
    NITRO
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    'zactly what I was thinkin. I may hafta keep the t case lowered cos of a bad vibration. If thats the case I'm going to find some square stock to beef up the gap instead of the spacers. Hopefully it'll work out. I did this months ago but I removed the swaybar for fun last week and the whole right side dropped /forums/images/icons/blush.gif
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had a similar thing happen with different results. smacked the transfer case on a rock. broke the tranny case!! 10qt's of tranny fluid still in the woods!! don't tell encon!! I plan on putting skid plates under this truck. If you take crossmember down, can you pull rails back?
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    You have me confused on the rails part. Are you talking about the braces that go from the tranny and tcase and bolt to the motor? If so, no, theyre not affected.
  6. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    if u bent the bottom frame rails, then yes u can pull em back into shape. id reccomend havuin a shop do frame work. thats what im doin. i dont feel like pissin with it myself and takin a chance of messin it up. /forums/images/icons/crazy.gif
    NITRO
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    what i meant was, if you take the crossmember out, will that release some of the stress on the frame and allow you to "pull" the frame rails back into shape.
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Thats what I did, I removed the old bent up x member, straightened out the frame rails best I could and replaced x member with a newer straighter one. It looks a whoooooole lot better.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My new frame was mildly bent from the a******* at the junkyard that hit it with the forklift. All I did was put a hi-lift between the rails to spread them a bit and put the crossmember in.
