soo the wire between my alt and battery melted.. helo
Discussion in 'The Garage' started by rwright07, Feb 21, 2007.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    i was drivin on the freeway when everything electronic shut off completely. got off the road and looked and the wire from my alt to battery fried. awesome. had AAA tow home and now i need to fix it.
    i need to replace the wire first of all.. wondering what gauge and where the connection to alt is... never dealt w/ alternator stuff before..
    second of all i think i probly need to get alternator checked and see if the regulator fried and the alt started cranking out crazy amps.. correct?
    help me out again fellas
    thanks
    rick
  2. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    What year model any wiring upgrades?
  3. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Pull the alt and have it checked. While your there pick-up a new alt pigtail and some 12-10 gauge wire. If the alt is good replace wire, If it's not buy a new one and replace wires.
  4. rwright07
    Jul 30, 2005
    536
    corporate hobo
    its an 85, i believe stock wiring... at least to the alternator... engine was swapped and alot of other wiring isnt stock.
    about how much will a alt. rebuild run, how about a new one?
  5. bear76
    Oct 16, 2005
    1,065
    here
    The 100 amp stock alt I got was less than $100 from NAPA.
  6. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    hows the battery look?
  7. rwright07
    Jul 30, 2005
    536
    corporate hobo
    battery's look fine... im going to pull the alt and get it checked... if its out i will buy a new one... bla more money...
  8. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    Check your grounds. I had a cable melt when I forgot to put the ground wire back on the alternator bracket.
  9. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Dont be afraid to run a nice gauge wire back to your battery either. I know people who have ran 4 gauge, seems a little overkill but it should make the current flow alot easier. I know when Im done hooking up my dual batteries in my crew cab (after Im done with my tbi swap here :eek1: ) I will be running a pretty heavy wire back to the battery along with my 1/0 battery cables.
  10. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    X2:waytogo: :waytogo:
    The larger the larger the wire the less resistance it has, the more amps it can handle without overheating. I personly think 4 ga.(105 A)or 6 ga.(80 A) would work ahelluva lot better than the stock wire size. If yur wondering 1/0 is good for 195 Amps.
    Disclaimer:
    Ampacities based on MTW, freeair, at 140*F
  11. bear76
    Oct 16, 2005
    1,065
    here
    Sure it works better and am perfectly fine with increase in size, but I think he wants to keep it simple and stock is simple.
  12. lurtch-k20-(78-90)
    Nov 8, 2006
    55
    Troup, tx
    oooooh o.k. simple is good sometimes.
