Sooo many fuel lines?!?
Discussion in 'The Garage' started by skink4president, Jun 20, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    I'm looking to put an after market Edelbrock fuel pump on my K-5 (350) but I'm already sensing things aren't going to be "Plug N' Play". Two questions:
    1) Am I going to need to convert the pump to bottom feed for clearance purposes?
    2)This is the first vehicle I've built that originally came fully emissions equipped. The 3 fuel line thing seems troublesome. Although I'd love to keep the Evap system that is currently in place I can't see how that's possible with an after market pump. Is there anyway to SAFELY vent the tank (maybe even retain the Evap system) without using an OEM fuel pump?
    Thanks Again!
    PS - can anyone recommend a good source for Stainless lines?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its tight down there even with a stock fuel pump , right next to frame rail . I hate changing fuel pumps .
    You can keep the evap , its a seperate return line .
    The tank is also vented at the fill neck .
    Personally I would just run the 15 buck stock pump , and carry a spare . Don't really need too much if you aren't drag racing . Just me though :D
  3. dyeager535
    26,980
    I concur. No reason to replace a stock pump with something "better" unless you absolutely need it.
    Safely venting the fuel tank is very troublesome IMO. Finding a safe location to vent, while keeping bugs/water/etc. out of it is difficult.
  4. kkyle69
    kkyle69 Registered Member
    Mar 9, 2005
    13
    Huntsville, Texas
    I would recommend The Fastenal Company for the Stainless Steel. I got my from there for about 11 bucks for 10 ft. You'll have to bend the line yourself and they have all kinds of sizes.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    stick with the stock pump, if you do anything put in an electric backup pump. It plumb into your fuel line w/ a bypass so most of the time you dont run it, but if you get vapor lock or your pump goes you have a back at the flick of a switch
  6. dyeager535
    26,980
    Also another reason to stick with stock pump, if going aftermarket removes the fuel return feature.
    The longer the fuel sits, the more likely it is to heat soak. With a two+ line pump, one of the lines is a return, meaning cool fuel from the tank is ALWAYS moving through the lines, instead of sitting in the lines picking up heat.
