sorry another 700r4 question
Discussion in 'The Garage' started by protechk5, Sep 2, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    ok just put another 700r4 in, adjusted the cable right but it is shifting way to soon. It gets up to OD way to fast. I did a search but could really find anything for shifting too soon. Again I adjusted the tv cable, so thats not it. Thanks alot
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did it happen to come from a diesel truck? The governor in a 700R4 from a diesel application will upshift way earlier than one built for a gas truck. You can either change the weights and springs on the governor or just swap one in from a trans that was behind a gas engine.
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    check the switch on the brake pedal, too. i had one go bad.
  4. protechk5
    Sep 26, 2004
    2,015
    VA
    i dont think it was out of a diesel but i could be wrong, how do i check the switch on the brakes what is it anyways, the lock up for the tc??
  5. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    If your shifting servo isn't working right it'll do that...
    ask me how i know...
  6. protechk5
    Sep 26, 2004
    2,015
    VA
    anyone else have any ideas?
