Sorry.. nubie question...Is this a dana 60??
Discussion in 'The Garage' started by k5 krawler 50, Aug 22, 2005.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I was wondering if someone could tell me if this is a dana 60 housing or not.
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    nah...ill happily take it off your hands for you :D
    jk, it is one...but ill still take it off ur hands for ya.
  3. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Sorry, but i gotta keep this one. How were you able to tell its a dana 60 housing and not a 44? Thanks.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I can tell by looking at the raised portion of the diff cover around the fill plug.
    And the bolt holes instead of the u-bolt.
    And the inner C's. Kingpins....
  5. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    awesome thats what i wanted to know. Thanks.
    Cory
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its a 60, try to pick it up, if you cant its a 60 :D
    There are no balljoints, only 3 u bolts used, 2 bolts for the other.
  7. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    hopefully, i will be able to grind off those little brackets on the spring perches, and still have an ok surface for the leaf springs. Does any one have a good sugestion as to going and grinding those brackets off the spring perches? THanks.
    Cory
  8. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    If you look on the bottom right corner of the housing there should be a "60F" cast into the webing.
    troy
  9. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I'd start on the welds with a cutoff wheel and pry bar first. Then grind the welds clean. Wonder what kind of jerry rig they were used for? Maybe some brackets for 1.5" springs on an escort :rolleyes:
  10. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    cutoff wheel to start............BFH to finish :D
  11. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Ah you lucky kid, how'd you come across that?
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Maybe some form of 3 link? It looks like there is 1/2 plate on the pumpkin on top. What ever it was it sure was jacked. :eek1:
  13. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    yea the guy said the owner before him had some lame ass link setup going on. Thanks for the help.
