sortof figured out why I'm confused
Discussion in 'The Garage' started by skelly1, Apr 15, 2004.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    sortof figured out why I\'m confused
    I've read the tech articles on the caliper grinding of the 3/4 ton and 1 ton and the 6 to 8 lug conversion on the D44/10bolt front. If I convert my 10 bolt front to 8 lug, which according to the article does NOT mean I need to change out the calipers, will I need to still grind the caliper down to fit 15" wheels with 4" of backspacing on them? That's the confusing part. I guess I just don't understand the difference between D44, 10 bolt, 6 and 8 lug, and D60 calipers/backing plates? I can sort of fathom a taller backing plate with a bigger radius rotor and wider pads in a 3/4 ton vs. a 1/2 ton, but I guess I am confused there.
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Re: sortof figured out why I\'m confused
    No grinding is needed, they are the same size ... just a difference in lug nut count. Here's some more info on the differences.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Let me try and clear some things up:
    You are correct in that you can use the same calipers (from your 6 lug 10 bolt) on your 8 lug 10 bolt. The difference lies in the size of the backing plate. When you swap on 8 lug stuff, you're swapping from the spindles out...so, that's backing plate, rotors, and hubs. On a 3/4 ton front axle (8 lug), the rotors are larger (better braking), so you have a larger backing plate, and thus the caliper interferes with the rim.
    In answer to your question directly: yes, with 4" of backspacing and a 3/4 ton front axle (10 bolt or D44), you WILL have to grind. I would venture to say anything less than 3" of backspacing and you won't have to grind.
    I pretty much explained that above, but it sounds like you've got the basic concept. /forums/images/graemlins/thumb.gif
  4. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Because you use the same calipers makes me understand.
