sound dampening a M1008, 6.2
Discussion in 'The Garage' started by huntsonora, Jun 14, 2004.
  1. huntsonora
    huntsonora Registered Member
    May 18, 2004
    15
    Any suggestions on how to sound proof the cab? There are a ton of products on the market that say they are the best but I am looking for some people with experience. I have a M1008 with the 6.2 diesel and am thinking about putting the material under the headliner I am putting in, under the carpet I am putting in and behind the door panels but I am wanting to know the best products for this and what type of noise/heat reductions to expect. Also, would the material that goes underneath the hood be beneficial?
    Thanks,
    Drummond
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Look for a product called Peel N Seal. It is sold at hardware stores and is just as effective if not better than most automotive insualtion products and much, much cheaper /forums/images/graemlins/thumb.gif
  3. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    I'll second that!!!
  4. huntsonora
    May 18, 2004
    15
    Thanks guys, I'll look into that. Is this material good for heat reduction as well? Also, any thoughts on the pad that goes on the underside of the hood?
    Thanks,
    Drummond
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The insulation under the hood should help keep the noise down a bit, too.
    I have question for you: Does your truck have the black plastic silencer attached to air cleaner neck? If not, you might want to find yourself one- the silencer does a great job of reducing the noise output of a 6.2....
