sound dead - dynomat
Discussion in 'Audio' started by khotmer, Sep 30, 2003.
  1. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    Just htought i would give everyone an old tip. It may have been covered but here is a cheap solution for sound deading your cab.
    Roofing tar paper and 3M spray adhisive. 2 layers is equal to dynomat and is 1/10 the cost.
    I have had good luck with it and it applys easy.....
  2. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Polymeric Mastic from McMaster Carr is also a good economical choice, and it already has a strong adhesive on it!!! About 1/6th the price of Dynamat IIRC.
    I've been spending a LOT of quality time with this product lately. So far I've installed two layers throughout the Suburban floor area (something like 5 or 6 full sheets) and I still want to do the quarterpanels and inner door skins.
    It's already made a BIG difference in noise reduction. /forums/images/graemlins/grin.gif
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah Greg is right there, I put about 10 sheets in my Jimmy. WOW what a difference! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Just use a heat gun to make sure it sticks well, and it helps it fit to the contours.
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    thanks for the info greg, my current rig is noisy as hell, and I dont mind it at all.. but at some point when the S-10 cab goes on Im gonna make it sorta civilized (yeah, trying to get the woman to wheel with me!) so maybe this would help. /forums/images/graemlins/grin.gif I plan on Line-X'ing the cab inside and out, that oughta help quite a bit too. At any rate, thanks,
    j
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I used some of that stuff in my roof of my s-10. I used some noise killer paint, some peel & seal roofing material as well as the padding (more to insulate heat than sound but it does help the sound some as well).
    I just finished doing the floor of my s-10 in the same way (4 layers of the paint, 1 of the roofing material, 2 layers of padding, and the carpet). Along with the other work already done I almost can't hear my exhaust leak /forums/images/graemlins/eek.gif. Next I just have to do carpet and padding on the back wall and the doors...should sound if not like a Lexus maybe more like a new truck /forums/images/graemlins/thumb.gif. The only thing I have had a hard time getting rid of is wind noise around the windshield...don't know what I can do about that.
  7. I bought 2 70 sq foot rolls of brown bread and covered the entire floor and up the sides of my Sub. Didnt have enough for the doors or roof, but it made a big difference.
  8. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    I am having a difficult time finding that product on their web page, can you give me a link to the actual page of the product? /forums/images/graemlins/thumb.gif
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
  10. kw48653
    kw48653 Registered Member
    Sep 16, 2003
    86
    i tried lytherm. kind of expensive, but it is super quiet inside. extra benefit is that no heat comes throught either. nice in texas!
  11. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    some other really good and cheap sounddeadeners check out edesign's EDEAD its 60 mils thick and easy to use and sticks to anything and another one is rammat also 60mils thick and pretty cheap
  12. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    I checked on my hunch today....Torch down roofing ....its -3/16 thick ,3' wide ,36' long and 50 bucks a roll ....available at your roofing supply store ...get it without granuals...It wount absorb any water too!!
    I have thought of using ....Pergo flooring cushining or the rubber membrain that is used under tile shower pans ...,both avaiable at home depot !!!
