Sounds in front end....differential?
Discussion in '1983-2005 S-Series models' started by globaljames, Dec 1, 2005.
  1. globaljames
    globaljames Registered Member
    Apr 2, 2004
    AZ. Scottsdale
    I have a 1994 S-10...
    A sound has come to my attention that concerns me....I have also apparently lost some fluid somewhere....
    It sounds like a rubbing/vibrating, and "feels" like its holding the truck back...
    I hear it most of the time, but have noticed that I DON'T hear it when the tranny is not being worked (coasting downhill/coasting level)
    VERY bad when going uphill....
    This is in 2 wd....4 wd WILL engage...
    I've never taken my front end apart before, but I don't mind giving it a go...
    I have the manual...
    Any insight into what this might likely be?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    Ann Arbor Mi
    Before you tear every thing apart check all the front end wear components. Ball joints, Idler arm, tie rods. Another common problem i have seen on theses is the torsen bar rubber mount breaking which can cause some front end noise.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    Oakridge, OR
    I don't see how it could be front end related when it changes depending on if you're under a load or coasting down a hill. It's gotta be in the drivetrain that's in USE if it's louder up a hill than it is down a hill. Probably in you tranny, I know mine is getting noisy. I don't know what tranny you have, but if it's a T5 like mine, I probably know what noise you're talking about.
