sounds like a leak?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88GLAZER, Oct 14, 2003.
  1. 88GLAZER
    88GLAZER 1/2 ton status
    Nov 19, 2002
    111
    West Virginia
    I have now tried about everything in the book to try to get rid of this sound that sounds like an exaust leak, but now I am not to sure. I cut the header flanges, so they are not warped, new ultra seal header gaskets with MEGA COPPER high temp sealer on them. As for the collecters, dead soft copper gaskets with high temp seal, and still this noise persists. It makes my truck sound like apiece-O-[darn]. could it be anything else?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Run your hand next to it and feel for leaks. Are all the seems welded? A bad weld or crack could be the culprit.
  3. blaz72
    blaz72 Registered Member
    Oct 7, 2003
    28
    connecticut
    Alot of hedders come with pin holes in the welds around the tubes.Hard to get to spots usualy
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Are you sure the leak is under the hood? I agree try runnin your hand around the headers where they mate with the engine. Also, it sounds kinda stupid but, look all the way up and down the exhaust system for carbon. If you can see black there's where your leak is. Good luck to ya.
    Allan
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    instead of my hand i like 2 use a piece of long heater hose held to my ear and listen for the leak then run it along as those dam headers can get hot quick
  6. 88GLAZER
    Nov 19, 2002
    111
    West Virginia
    good advice! I just burned the hell out of my pinky
