Source: deep steel TH350 pans
Discussion in 'The Garage' started by BadDog, Jun 2, 2003.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm looking for a +2-3 qt TH350 pan in steel with no chrome and no funky tube things. Just a deep steel pan. Does such a thing exist?
    On aluminum pans. The adverts speak of increasing the tortional rigidity of the case by using an aluminum pan? Is this a significant amount and worth consideration, or is it hype?
    I'm not looking for cooling (other than that provided by extra capacity), IMO the pan is not much use in this respect. What I'm looking for is keeping the pickup submerged until well beyond the point I go over in any direction...
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I don't know of any deep steel pans that aren't [bling] chrome [bling]. I haven't crossed any reports of how much the aluminum pans add strength, but it seems logical that they would (don't know as it is necessary or not, if the case is stout enough I would imagine it is negligeble). What I do know is that the deep aluminum pans do help in cooling if only through extra capacity. The deep pans that are sold for the automatics behind Cummins motors add 4qts capacity and claim that they do more for cooling through capacity than many aftermarket coolers (no brands of coolers mentioned) do with a stock pan. Take it for what it is worth, but I thought I'd let you know.
    Nick
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Turbo 400's came from the factory with a deeper steel pan, and a filter extension tube in 4WD applications. Does anyone know if the Turbo 350 had a similar variation? That would be the easiest setup, to just find one in a junkyard. /forums/images/graemlins/cool.gif If you can't find one aftermarket, it wouldn't be too tough to weld one up. Slice a pan in half and then weld in an extra inch or so. /forums/images/graemlins/thumb.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I wasn't aware of the deeper pan. I guess maybe that's why TH400s are known to keep pulling at crazy angles when a TH350 looses pressure. On the welding, I don't think my welding skills (particularly on sheet metal) are sufficient to weld it up without leaks and/or warpage... Sounds like a job for a TIG...
  5. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    TIG you say?? We'll have to chat.
  6. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Aluminum pan's will dissapate heat faster then steel pan's, just something else to consider. /forums/images/graemlins/blush.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks anyway but I've seen the one in JCW before, I'm a bit concerned about the quality of that one. Likely pretty weak and I don't like chrome for multiple reasons.
    Also, I know that aluminum disipates heat faster. However, from what I've seen the effect is marginal at best. Coolers are for cooling, the added volume helps some too, but the improvements due to an aluminum pan are too small to be of much use. There are 2 primary reasons I don't want aluminum; it will crack when hit and it costs more than I think it's worth. However, that may be what I get if I can't find what I want...
  9. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    do you come up this way to vegas very much? if you do, there are a few shops here in town that sell those pans also. if you want, i could send you some of there names, and phone #'s. i checked around for a buddy of mine a while back, most of them carry them in stock, i think.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmm, then I should be able to find one locally. I called several shops and suppliers in Phoenix but they generally say "only aluminum" or "only for TH400", etc. Mostly just a random sampling of local shops, I'll keep calling around to see what I can find... If you can PM with some numbers of guys local to you, who you think might have it, that would be great. If I can't find it locally, I may just have to pay one of them to ship. Thanks...
  11. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    you gotta pm!!
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i feel the aluminum pans with the fins are better. they do cool better, even though i know you said you dont care for that. they are more rigid. yes they are more brittle and will crack before they bend. but if you punch a steel pan yer still going to leak. the alum pan is stronger.
    i have only seen chrome pans in larger capacity. i think they do that so the amount of temp the chrome brings the fluid up the extra fluid makes up for it. i think if you want steel you have two options. fut one up and expand it. double welding it inside and out to make sure of no leaks. then sandblast it, clean it aout with isopropal and leak check it before putting it on.
    option number two would be buy a chrome one and sand blast the chrome off. im sure somebody has one the chrome is all rusted up on they want to get rid of.
    Grant
