Source for axle rebuilding (specifically R&P's)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Jun 5, 2001.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Source for axle rebuilding (specifically R&P\'s)
    I have checked Barnes & Noble, Amazon.com, Chilton's, and Haynes and nobody has a good in depth Ring & Pinion setup book (just general overviews). Does anyone know of where to get a book with a GOOD IN DEPTH instructions on R&P setups.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Re: Source for axle rebuilding (specifically R&P\'s)
    Publications.....No.
    But you can get different websites that have write ups. But thats about all I have ever found. The R&P's usually come with instructions too. And added with what you can find here and from sites like:
    http://www.differentials.com/njtech.htm
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Call Summit Racing or Richmond Gear.... Richmond gear sells a video that shows you how to set-up rear ends. They go through most style of rears all in one video for about $18... Summit Racing sells it as well as others probably!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, got the video too. It was pretty helpfull. But they cram alot into 10 minutes, thats for sure. Not a lot of detail though. But worth the money.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    If your whating info on Dana(Spicer) Diff's , then get to know your Spicer supplier, there are deadicated manuels for
    all the most popular models (28,30,35,44,50,60,61,70...)
    I have had some luck in get some through 4WPW of all places.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  7. dyeager535
    26,982
    191
    The GM service manual has pretty good instructions (the ones I have seen) but typically use part numbers for their tools instead of actual names of them. All you typically get are things like "if pattern looks like this (picture) then you need to shim X this way" Not much more to it than that, except torque specs.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
