Source for Transfer Case Parts np205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by steve85fla, Dec 15, 2002.
  1. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    Anyone know a good quick source for transfer case parts? I am stuck fixing my son's '76 f250 np 205, which he ran dry. The bearing race spun and put a 3" hole in the aluminum cover which holds the rear bearing for the front output yoke. Probably ever bearing in the thing is toasted.
    Thanks! Steve
  2. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    What all do you need, just the rear alum cover? Any good parts store or mabe a trans/transfer cas shop should have a rebuild kit with new bearings and seals. If ya need the alum cover let me know I may have one.
  3. steve85fla
    Mar 27, 2001
    83
    Thanks, I am taking it apart today, I have another one that is good, only it is a "married" case-the busted one is "divorced". I am hoping the guts are the same. Input shaft is definately different though.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    You are right about the internals being the same except for the input shaft. You can swap the parts into the other easily. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  5. steve85fla
    Mar 27, 2001
    83
    It's in bad shape, all the bearings on two of the shafts are spun, I cracked out one side of the case today pressing out the idler shaft with a hydraulic press, the shaft is so damn seized onto the bearing race. I'll try and weld it up this week, glad it's steel-welds easy. I am tempted to convert the married box into divorced by welding mounting surfaces onto it, and put the input shaft on from the old one.
