Spacers and hummer rims
Discussion in 'The Garage' started by Ronnie4wd, Jan 8, 2004.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    How thick should the spacers be.I´m gonna put them on my Jimmy with 16.38,5.16,5 tsls.I was thinking about 3 or 4 inches what do you think or even better do you have a similar setup.
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I used Dual wheel front D60 hubs in the front and had some 3.5 inch steel spacers built for the rear. The spacers are hub centric and utilize 5/8" wheel studs. If you have a van width rear ff14 bolt use a 2.5 inch spacer.
  3. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Both front and rear came from a K 20 78 so 3,5" should be what I need.I don´t have my Jimmy at home now and have to order the spacers tonight.
    Thanks for the help. /forums/images/graemlins/thumb.gif
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i think tonyp was making some spacers if i remember correctly. yalk to him
    69k5
  5. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I just found that.He was making them 4,125"
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I am building a similar set up and I am using a dually front with 3 1/4" spacers on the rear (68" wms D70HD). If my math is good I figure I'll still be roughly 1~2" narrower in the rear. I would like to have a slightly bigger spacer but I got them second hand for a song so I'll live with the difference.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    these are the ones I made up, I had the hub turned so that the spacer would be touching all the way to the outside of the nose...
