Spacers between rear wheel and drum?
Discussion in 'The Garage' started by 85-454blazer, May 25, 2004.
  1. 85-454blazer
    85-454blazer Registered Member
    Feb 26, 2004
    14
    North Carolina
    I just bought a bone stock 87 K5 in very good condition. I plan on leaving stock for the most part and using as a daily driver and local shows, etc. I can't stand how the rear wheels set inside the fenders more than the front. Any advice or suggestions on spacers? Am I risking unacceptable bearing wear, etc. Thanks. /forums/images/graemlins/usaflag.gif
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,856
    282
    Truckee, CA
  3. 85-454blazer
    Feb 26, 2004
    14
    North Carolina
    Thanks for your input. 1 1/2 is what I figured also. Found a set on ebay - should be on the way. Will update with results. Thanks again. Jerry
  4. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Jerry huh. /forums/images/graemlins/peace.gif I've running a pair of 1.5 inch ers on mine for about 7 years now and had no problems, just had to keep re-torqueing the lugs till they fully seated which only took about 4 tries. They make up for the width difference in the axles. /forums/images/graemlins/thumb.gif
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    That's the key! A re-torque every 50-100 miles till they stay put. What did you torque them to?
  6. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    can't remember, I think it was 125lbs but not sure. They've been on there for years and everytime I remove the wheels I check them and they're tight.
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    It will make the rear end look really wide and some times its hard geting usto (talking form experience)
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I don't see how that could be. The 1.5" spacer per side will make it as wide as the front axle. Isn't that the whole point ??? To line up the rear tire track with the front tire track. Personally I would like my rear tires to line up with my front tires. I can run the same backspacing on my wheels and it won't look goofy.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I personally feel that wheel spacers are unsafe and would not run them on my rig, but to each their own....
