spacers inbetween xmember and frame on a chevy
Discussion in 'The Garage' started by down4thakrown, Feb 10, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the 4 that drop the tcase xmember.
    does the dealer ship sell these?
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    those arnt for droping it. get 2 sections of flat stock and drill hole and bolt in to spread load out or frame might crack.
  3. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    So do you still use the spacers then and just bolt the flat stock on there with the spacers? I had to drop mine for now on my '89 till i do the SYE and axle swap becuase I had a severe vibration. Will i have to worry about this if its only for a few months?
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    if you wheel it, yes worry about it, if only street, your probably fine
  5. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Oh ill definately be wheeling it, how should I go about doing this diferently then?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Leave it bolted up to the frame where it belongs. Lowering your transfer case is a piss poor way to attempt to improve driveline angles. Leave that to the jeeps.
  7. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    I agree with you completely but i jsut installed all my suspension stuff and will be doing a 14bff in a few months as well as a SYE so i dont want to go wasting money on a cv driveshaft until I do all the other stuff since im sure i will need a different length and what not for the 14b, but I still want to drive it in the meantime. Once I do all the other stuff i will hopefully be clocking the tcase as well as building a new x-member since the stock one has such piss poor clearance anyway! So this is only a TEMPORARY solution.;)
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    ok so my truck is going to break? my xfer case is lowered about 2-3".... I have been thinking of getting rid of that... It was done when the 12" leafs went under the truck and needed better drive line angles....
    but now with 8" lift should be fine... but it is done and seems tight....
  9. hunter
    hunter Registered Member
    Oct 28, 2004
    52
    Houston,Texas
    Exactly, you could make your own out of some 1" thick by 1-1/4" flatbar 4-1/2" long with two 3/8" dia holes at 2-1/2" center to center, then just buy longer new bolts and place that between the frame and the crossmember and do away with all the factory bolts and spacers.
    They actually sell these in a kit, but its tubing and not solid steel.
    http://www.suspensionconnection.com/cgi-bin/suscon/10702.html
  10. hunter
    Oct 28, 2004
    52
    Houston,Texas
    Took my own advice and made some this weekend out of 3/4" thick x 1-1/4" flat bar. The extra 3/4" lowered it enough to decrease the pinion angle 3degrees and my angle is now good and no more vibrations :D
    I will try to get some pics next week.
  11. sweetk30
    Nov 1, 2004
    25,547
    542
    i didnt say thay work good or bad. but easy to make. and the set i have is in there propor place in the garage on the pile of stuff that didnt work for me. every body to there own. glad it worked for you.
  12. hunter
    Oct 28, 2004
    52
    Houston,Texas
    I understand, if I had a lwb truck I would never do this, but with these K5's and there very short shafts, every little bit helps to fight the dreaded pinion angle vibrations.
