Spare tire well modification.
Discussion in '1936-Present Suburban' started by Mudbone, Jan 20, 2006.
  1. Mudbone
    Mudbone Registered Member
    Jan 19, 2006
    60
    NC
    I have an 88 3/4 Burb. Its stock except for the 33x12.50s that the PO put on it. (well there is that jungle gym of a homemade redneck brush guard/winch mount.) I plan to keep some type of large tires on it and they will not fit in the spare tire well. How difficult would it be to cut out the well and have a sunken tool box fabbed up with a flush lid? Also since two is always better than one, how would you re-route the gas filler neck so that I could put one on the other side?
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have no idea how tough it would be, but if ou do it take lots of pictures and post up.
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    depends, how good are you at welding sheet?
    if your good, then make a square box the same size cut out the wheel well, and drop the box in and weld it up make a lid.
    if yo still want to use it i have thought of getting a replacement, wheelwell from lmc or something, and cutting it wider, "tubbing" it out wider to fit a larger tire.
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    My yellow crapsman carry toolbox fits there. I put acouple rags under it so they dont fly around put the tool box in and there is room for a quart or two of oil and brake fliud on the sides. I put my 4 star in the well in front of the toolbox to keep it snug. Less than half the box sticks out and it all stays pretty secured. Plus you can take all your tools to the front of the truck when you work on it instead of walking back and forth.
  5. TRAILTOYZ
    TRAILTOYZ 1/2 ton status
    May 21, 2005
    106
    Wasilla, AK
    It would be cool to just cut it out and leave a hinged lid on it so you could...uhhh...use the facilities in private whenever you wanted :shame: :woot:
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    There's not alot of room to reroute the filler tube. Maybe you coud put it into the wheelwell with an elbow and some extra tube. I think the fuel cap assembly would unbolt and you could relocate. then you could make a little box behind the fuel door to "hide your weed." I know of a guy locally who cut out the tire well completely, put in a flat sheetmetal floor and trimmed the fenders right under the body fold line.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    So if you don't use the spare tire well, where do you keep your spare? :confused:
  8. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    its a 37" spare so it doesent fit the spare location anyways. Its just ratcheted down in the middle of the bed.
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    mines housing two optimas
  10. TRAILTOYZ
    May 21, 2005
    106
    Wasilla, AK
    Thats a good idea.
  11. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    Just make sure you don't have a tailpipe below it, otherwise... :haha:
  12. TRAILTOYZ
    May 21, 2005
    106
    Wasilla, AK
    I just pulled mine out. I'll prob make a hinged lid for it and figure something out later. I'm thinking about cutting another hole above the gas tank to make trail repairs on the fuel pump easy.
  13. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I was just going to remove mine and replace it with a flat piece. One of these days I will need the clearance....
  14. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    I like the idea of putting a lid over the well and usingit as a toolbox...nice and flush, so no A$$ will see my tools and try to steal them...
  15. cbbr
    Jul 17, 2004
    14,681
    It would certainly be a new way to deal with tailgaters.
  16. Uncle Fester
    Mar 23, 2006
    229
    Cheyenne
    Bombs Away!
    Talk about the S**t hitting the fan! LOL This feature would be great on a suburban with say....8-12 inchs of lift..get that Bomber effect! :bow::bow::bow:
