Spare tire ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Sep 6, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Will it be ok to use a bias ply spare tire. I will be running 35" SSR's and can get a 35" bias spare for next to nothing and was wondering if it will be ok untill I get another SSR.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I run TSL's which are bias and my spare is a 35" Kelly DTR which is a radial. I had to use it last year once. I drove about 25 miles with it on. I didn't notice much of a difference!
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Interco Co. says not to run bias and radial. they say you must have all 4 the same. Duno why just something I read when I got my SSRs......
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Every tire co will tell you that. I used to run my Charger with radials on the front and bias on back with no problems but never did it with a 4x4. And this will be just one bias. I would only use it on the rear so if a front would go I would take one from the rear and put it up front and only use the bias on the back, I think it would not be as bad on the back.
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    If you're only using it as a spare to get you back home, It should be ok. Running different bias all the time has been a constant no no as long as I can remember.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I was always told the same thing, dont mix. But I run radials all the time, and for the raunchy trips, I swap on my set of bias TSL SXs onto the rear and I cant tell any difference. And I carry one of the Swampers for my spare.
    Shoulb be great for a spare.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
