Spark Nock Sensor
Discussion in 'The Garage' started by Justin Fleming, Sep 22, 2006.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    Could a spark nock sensor create an open circuit and cause an 86 k5 not to start?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    no it should not, is the engine cranking but not starting , not cranking whats the engine doing?
  3. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    well
    The engine is cranking but no spark. all new dist. cap rotor wire plugs ignition switch..........It just dont make sense
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    check the restance on the pickup coil, this is under the cap and plugs into the ignition modual. it should be around 1500 ohms i belive
