Spark Plug debate
Discussion in 'The Garage' started by moneypit, May 1, 2005.
  1. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    What do you use and why???
    What performance gains did you see??
    I got a line on the Denso Iridium plugs for cheap. Can't seem to find any input from users. Anyone use them? They seem to average $12 online each!!!! (not what I pay)
    Seeing how I have the headers off amongst other things now would be the time to change them.
    SOOO let the debate begin...... TIA -MONEYPIT
  2. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    I use Accel U-groove header plugs because I don't want toasted wires.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I run acdelco R45TS gapped at .060, theyre good, cheap plugs. Im thinking about goin down a heat range or 2 for a few more hp, as I understand a colder plugs give more hp, and as my friends know, Im a horsepower junkie....
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I use NGK V-Power. As for my reason, well, i've ran many a different plug over the years and these last the longest, give a smoother idle, and aren't expensive. :thumb:
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I just use the AC Delco standard equipment, because they make the engine run, no problems with them either, had a set of free Splitfires in it before, they lasted about a year and a half before i yanked them, ran good, but did not notice any difference in the two.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I had those on my burb and will never use them again. I pulled them out a few weeks ago and the gaps were huge. I definetally gapped them on install. There was one AC Delco plug in there(broke one of the accels) and it was still gapped perfectly. I'll just dent and bend header tubes from now on.
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I like regular AC Delco R44TS's or the NGK V-Power equivilent for the Burb. I've always been pleased with the performance of those two. :D
  8. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I'm a regular standard autolite fan; cheap and durable.
  9. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Delco Resistors, most reliable plug I've ever used
  10. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    AC Delco CR43TS for me, never had a problem with em. I usually put fresh ones about every 10-12k with new cap and rotor.
  11. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    stock AC delco. PITA to install with headers tho :mad:
  12. 79 blazer
    79 blazer 1/2 ton status
    Dec 29, 2003
    114
    FORT COLLINS,CO
    of course theese would be the best, they are made buy the smae guy who is responsible for the "spiltfires". man that is so much bullsh*t that they cant be made. we should all right a letter to congress or all request them from a manufacturer or something, maybe if we could get a mass order together he would make a batch just for us. evryone at leaste check out this site and read the whole thing, it is amazing once you realize that this is real and not a gimmick.
    http://www.robertstanley.biz/firestorm.htm
