Spark Plug gapping
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Mar 20, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Since my 85 has a rebuilt 350 I have no idea what to gap the plugs at, it has about 20k and I want to put in some platinums, But I have no idea what to gap the plugs at, is there a general standard that can be used?
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    .045 works for me.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The book may say .035 but I go .045 for more spark!
    Any were in this range will work fine.
    Burt4x4
    Rock ON!
  4. SVBlazer
    SVBlazer 1/2 ton status
    126
    Boxford, MA
    If you have an aftermarket ignition like MSD or Jacobs you might consider a larger gap. I run .060 with Jacobs.
  5. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Even going to just a hot coil and good quality wire set should allow an .050 or larger gap to work
    John
  6. _DeeVee8_
    _DeeVee8_ 1/2 ton status
    149
    oh, and one more thing-- there is no real difference between the regular AC 90 cent spark plugs and those high and mighty platnums--
    you won't see any real gains--except a decrease in the width of your wallet!
    -Dv8
