Spark Plug Wires - UNrecommended :-(
Discussion in 'The Garage' started by HarryH3, Oct 2, 2005.
  1. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    For the last 15 years or so, I've been a big fan of Taylor Spiro-Pro plug wires. I really liked the fact that they came with a lifetime warranty. But I have a set that have failed, and now arc all over the engine bay. Imagine my surprise when I called Summit Racing to have them exchanged, only to learn that Taylor now only offers a 90 DAY WARRANTY :eek1: :eek1: :eek1: You can read the actual warranty here: http://www.taylorvertex.com/hp/warranty.aspx
    So I hereby retract ANY recommendation for their products!!! :angry1:
    I have sent them an email asking them to exchange the set that I have, because I still have the piece of paper from the box that says mine came with a lifetime warranty. We'll see if they at least honor that. :rolleyes:
    I guess the good ol' lifetime warranty Autolite plug wires are looking better. At least they only cost around $20. :wink1:
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I really like my MSD Super Conductor 8.5mm wires. I don't know what there warranty is but I have had my set for over 4 year with no problems.
    Harley
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Autozone baby, el cheapo, a definate lifetime warranty, always worked fine for my application :waytogo: maybe not the best brand name on the market, but with a stock motor,,, :dunno:
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    My bet is they will honor YOUR lifetime warrenty,since you have documentation to the fact.
    Just keep on them about it.
    Good luck.
  5. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I had a set of the MSD super Conductors and they did the same thing arced all over the place by the plug boots. Sad that the $ 100.00 MSD's only have a one year warrantee while the less expensive Autolite professionals come with a lifetime warrantee. The real sad thing is that I sent MSD two e-mails and a letter requesting that the three wires that were broken be replaced and they didn’t even replay. So much for “Customer Service”.. MSD LOST me as a customer, I will never purchase another crappy MSD product.
  6. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    I have some napa cheapys they work great . :D
  7. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Don't normally hear those tow words in the same sentence :doah:
  8. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Huh, and I thought MSD was good stuff. Guess not. Customer service to me comes before everything. If a company does not believe customer service is a top priority and treats it's customers like that, there's no point in doing business with them, even if their products are actually good.
  9. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have the same problem with Jacobs.
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    MSD used to have a problem with this and that's why they changed their boots to a different material that elminated that issue and also has a much higher resistance to heat. They also have a 5 year warranty now, not sure what it used to be. I've run MSD wires for 20 years now and have never had a problem with them. They are the best wire if you have headers and the wires are anywhere near the header tubes.
  11. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    if they won't help you after that, tell them you will have your lawyer contact them
  12. westcoastblazin
    westcoastblazin Registered Member
    Oct 3, 2004
    15
    I agree, I have the same wires on my SBC, they work great.
  13. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    That sucks. I, too, have been running Taylor Spiro-Pro for as long as I can remember. I've always replaced mine because they got dirty (usually around the 40,000 mile mark when I do an entire ignition tuneup) and used them as spares or to put on some junker (AKA friend's vehicles) to get it to run.
    It sounds like I might have to switch to Accel or something. If they're only going to warrantee them for 90 days then there must be some kind of problem with them.
  14. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Factory Parts
    AC Delco cap, rotor, & wires. Good enough for millions and millions of GM cars, good enough for me.
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I have a set of the Taylor Spiro-Pro wires on my S-10 that have been on there for at least 10 years. It also has headers, so I would have expected that set to fail first. The set that failed on the '94 Sub only lasted about 5 years, on a bone stock engine.
    Meanwhile, my '90 Sub has 159K on the clock and the wires appear to be the factory originals. Right down to the cylinder number printed on each wire. :cool1:
    I guess I'll be going back to $20 wire sets from Autozone. :doah:
  16. Emmettology 101
    May 9, 2000
    8,126
    FL
    I dont understand why you would change just because of the warranty period? They last a very long time and much longer than most other wires. They are cheaper or the similar price to other wires.
    If you go buy Auto Zone or whatever brand cheapies, you'll probably get a similar 90 day warranty. And then you'll more than likely have to replace them after a year or so. Then you'll have more money into wires when you could've just stuck with Taylors that will last.....
    I do agree that they should honor your lifetime warranty. You bought a product that had that warranty. Just because the newer stuff is less, they still have to honor the prveiously purchased products.
  17. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Anyone ever tried Magnecor Wires? Given the price of MSD ("Major Sh!!ty Device" to some ppl) wires I'm tempted to try some.
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Back when I had my Probe, alot of guys ran them. Heard alot of good.
    Most in that crowd liked the NGK wires better.
  19. 4xcrazy
    Oct 31, 2003
    9,471
    5
    hmmm, i have had my set of "LIFETIME warrantied" wires on my truck for alittle over 2years, with no issues as of yet, and as it says,,,
    "LIFETIME warranty" :p:
  20. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I run the Bosch wires from Autozone. They are like $30 and I just use the warranty to get new ones every couple of years.
