Spark Plug Wires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Dec 2, 2000.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I was just wondering what ya'll thought of Borg Warner spark plug wires. I have a set on my K5 and the mechanic I go to thinks their crap, even though I just changed them a few months ago.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I never heard of BW spark plug wires, but If you want some better ones, get some MSD super conductor wires or some Taylors. They are both really good, but the MSDs are expensive.
    90K5
  3. Gold Rush
    Gold Rush 1/2 ton status
    1,498
  4. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I've seen many posts about Jacobs wires...all positive. I plan on replacing mine with Jacobs as soon as I hear the first misfire from under my hood.
    For the newbies, the same posts said the Jacobs Electronic Ignitions are to be avoided. MSD's get all the praise in that department.
    '89 K5 Silverado 4" lift w/BFG 33's
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I've used borg wires before. they were ok not great but ok. For the chevy HEI ignition your wires should be the 8mm size. I've found that 7mm tend to leak voltage and cause small misses.
    To see if your wires are shorting,Pop the hood. Look at the wires with your engine running in the dark. If your wires are shorting you will see the sparks shooting out from the wires. If you see small sparks replace them. Taylor, MSD, Jacobs,Mallory all make good wires. I've never had good luck with Accell wires.
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    To each his own on this one, but unless your engine is modified, don't waste your money on expensive plug wires because the benefits don't out weight the costs. Use GM replacements.
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I had bad luck with Taylor (blue) wires with my stock HEI '87.
    I changed to NAPA Gold 8mm lifetime. They have been on 4 years now and
    no problems. Just my experience....
    SteveB
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Keep in mind that all mechanic have their own opinons(my dad did!!). Unless an engine is modifided, I believe you stay with OEM AC Delcos. GM spent a lot of money doing research on them for there engines. Who am I to second guess the people who made the engine. Just my (mechanical) opinon!
    blazen91
    Protect the land FOR the people
    <font color=red>Not FROM the people</font color=red>
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Gm engineered their wires to be 'just good enough'. Same reason 10 bolts became stock equipment. Its just my opinion, but 'just good enough' doesn't fly on my truck. I use 8.5 mm spiral core wires, a hotter coil and some platinum plugs. It runs better now than it ever did.
    If you want real reliability and longevity from your truck there are some parts that must be upgraded. Again, just my opinion, but I plan on having my truck a long time so overkill is just enough![​IMG]
    Rene
  10. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Did test between napa gold ac delco and accel super stock all 8mm. Ac plugs had least resistance per foot, than accel than napa gold. Can't remember exact figures but ac delco was best by far. Napa and accel were very close.
  11. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I had a bad experience with Accel wires. One of the HEI connectors became all rusted and caused misses. I switched to MSD red 8.5mm wires and no problems at all.
    If you want to save about $20 on these wires, buy a 25ft roll of cable, a pack of 9 HEI connectors and a pack of 9 spark plug connectors. Cut them and crimp them yourself. It's very easy. That's what I did and no problems at all.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,078
    486
    Grand Rapids area
    Hey for a great deal, check out the Bosch "Super Premium" cables at Autozone. They are 8mm, spiral core and similar to a lot of $40-$50 wires. They are only $20 for a Blazer, though, even though the same brand costs more for other vehicles.
    "All right...who keeps squirting this oil in my driveway?"
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    I run Taylor Wires from Summit Racing. They have never let me down and I have been running them for years! Also, they are only about $40 at Summit!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  14. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I too am running Summit Brand 8mm and I mesured the resistance for every wire after I crimped it and they all, even the longest one had very low, less than 80ohms,of resistance and they have worked like a champ ever sence. Well worth the 40 bucks!
    http://www.burt4x4.coloradok5.com
  15. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    While we are at it, what plugs do you guys use? What gap would be best with stock hei and good wires? How about caps also, I need to do my first tune up since I bought my rig. thanks.
  16. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    I always use ac delco plugs. Also use either an M.S.D. cap and rotor or accel. Never any trouble out of either. Gap .035 for stock ignition system.
  17. FLWIV440
    FLWIV440 Registered Member
    Nov 21, 2000
    32
    what 90k5 said the msd wires are great. spend the110 dollars they are worth it!!
