spark plugs and headers?
Discussion in 'The Garage' started by Jonny-K5, May 29, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    just put a set of thorleys on my K5. any tricks on getting sparkplugs tight? half of them i cant get a socket on. barely can get my fingers around them. should i try to use an open end wrench? im not even sure i can get that in but i dont know how else its possible.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Should try the shorty plugs,then slide the socket on, and use a wrench on the end of the socket. I dunno what to say about your current situation though.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    never heard of shorty plugs, ill have to give them a try. thanks
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I used the original (non shorty plugs never heard of them) took the rubber out of the spark plug socket, put socket on, use a wrench on the end of the socket.
  5. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Not to hi-jack the post or anything but what about plug wires? Any secret to not melting them?
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Two words. "ZIP TIES" /forums/images/graemlins/rotfl.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Do you have straight, or angled plug heads? Im guessing straight. 90* wires work fine on my straight plug heads and thorleys. 45* and 90* wont.
  9. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Taylor wires are great. I had one that ended up laying on the header for a short road trip and the wire was fine. As for wire separators, MSD t-locks are the only thing I've found that can hold up to the heat.
    With my Thorleys I used three methods; open end wrench, spark plug socket with rachet, and spark plug socket with end wrench. One plug on the driver's side was easier to get from the bottom.
  10. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I definitely use some of my 4-letter vocabulary when changing plugs, but it's not really THAT bad with a box wrench or open-ended. Just get in the mindset for a not-as-easy-as-it-should-be task and you'll get through it. /forums/images/graemlins/deal.gif
  11. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I used an end wrench to tighten mine. In places that i coud use a socket i did. but that was prolly 2 outta the 8. So try the end wrench thats what i used, maybe that will help you out.
    Cory.
