spark plugs and headers.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nyyef, May 29, 2000.
  1. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    how do you guys and gals avoid burning your spark plug wires on your headers?
    does anyone recommend a brand of wires?
    thanx
    Knife.
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm using MSD 8.5mm (red) wires. They have huge sparkp-plug boots. Besides I used DEI boot protectors which are some kind of heavy-duty cloth covered with aluminum foil. The wires go through Spectre wirelooms. The attachment show the DEI boot protectors being installed on my old Accel cables.
    I got everything from Summit. I saved about $20 by ordering a 25-foot roll of bulk cable, connectors and boots and crimping them myself. The trick for not burning them with the headers was to tighten the wire loom so that there's not enough slack for them to touch the header.
    If you do get the DEI boot protectors, order the bulk cable because the big boots on the pre-assembled wire won't fit through the protector.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  3. Blazer79
    1,816
    Oops! forgot the attachment. Here it is.
  4. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    I've got 8mm Accel wires on an HEI distr rigged with Fiberglas sock tubing from the local hot rod store. It comes in a bulk roll. You have to fab the booties yourself -- about 6" each. Make a 7/8"-1" ring outta baling wire, tuck one end under and secure with ziptie. It's cheaper than the prefab booties. A mech wanted to know where I got the Asbestos! It may be in crayons but it's not in fiberglas. Although it does look, smell and taste like asbestos! (?)
