spark plugs
Discussion in 'The Garage' started by ronnny, Mar 25, 2005.
  1. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    What plugs do use in your chevy and why?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    AC because they perform better and last longer.
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    AC Delco's
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I used to run Bosch Platinum but switched to AC after seeing the results of the last Spark plug post.
    The AC's give an easier start in the morning & mileage is better.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    AC Delco. Because theywork the best. Are there other kinds of spark plugs? :what:
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    AC Delco, also after seeing the last big post on this.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    AC DELCO R45TSX
    in all my SBC engines
    why ?
    because they are extended tip
    and they always burn a perfect nice light tan and no bumps or black or oil or wet at all, not even a trace
    can flip the ign switch as fast as i can and engines will always start right up immediately and idle, not even have to touch gas, unless is cold, then pump once to set choke
    great plugs 10 out of 10 score :D
    i am really super picky about what i run in my engines, only AC plugs and oil filters, only mobil 1 or havoline oil, oil will not be left in long enough to turn dark before i dump it,
    very picky, my engines have to run perfect and be spotless or i will be pissed
  8. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i have ngk's cuz they are short enough so im not burning plug wires on my headers, the Accel's were to short and expensive...
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    AC delco, they are cheap and work great. i have thought about trying some NGKs next time though, its all i run in my bikes.
  10. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    OEM plugs...
    I usually use AC plugs--why??--because thats what they came with factory--but I've used Autolite plugs with good results. I never liked champion plugs,maybe they are better nowadays since they went to a "copper plus" design,but I had too many of them croak at low mileage,and I was not impressed with their performance..they seemed to die if you flooded them,an AC plug will come back,but once a champion plug gets flodded,it wont start until you put new ones in..
    I had poor luck with NGK plugs in my Honda C110 I had as a teen,I hated them with a passion--I finally found a place to buy autolite plugs that fit it,and only had to replace it twice!--I bet I put 50 NGK and Champion's in it in lss than a year--it would just shut off and refuse to start,and it had good spark!--put in a fresh plug,it would fire right up!--so I wont waste any money on NGK plugs,or Champions in my chevy's...
    Another reason why the 6.2 Diesel is superior!!--Real trucks dont have spark plugs!--or Coils,Distributors,Wires,Points,Modules,Condensers,Crank Sensors,Carbs---:D :D
  11. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    AC Delco everything!
    Where is the last spark plug post?
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    AC Delco's with my TPI 350. They run just fine and stay clean. When I had a carb the motor didn't run as clean and would foul plugs after awhile. When I ran a carb the motor seemed to like Champion Truck plugs (#4018's) the best.
    Harley
  13. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    the brand thats supot to be in it A/C DELCO and yes i have heard good about auto lites if needed.
  14. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running the Accell Header plugs on mine. Have ran AC Delco's the whole time before these, just trying them out to see how they perform....
  15. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Accel Shorties so I also don't toast my plug wires on my headers.
