spark plugs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 75blazer454, Oct 16, 2002.
  1. 75blazer454
    75blazer454 Registered Member
    Oct 1, 2002
    27
    Norge, oslo
    i cant get my enegine over 4000rpm.
    if i have spark plugs thats made for 80mod in my 73mod enegine, can that be my problem?
    i dont have HEI.
  2. dyeager535
    26,979
    Probably not enough to have a sudden, drastic change like a brick wall that you can't break.
    What exactly happens when you reach 4000RPM? Does it start "cutting out"? Is it repeatable at idle and when driving?
  3. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    when i reach around 4000 and hold the pedal to the floor it sounds like i have "explosives in my headers".
    but from 500 - 4000rpm everytings works normal.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did you say no HEI?
    Do you have points or do you have an aftermarket electronic ignition?
    With the points you could have that exact problem if the points are going bad or the gap is small
  5. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Get an HEI, its easy to put in and makes it run a lot better. Im not sure if it would fix your problem though, I just know I love mine after platying with points
  6. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    i have the original one whit points. its a 73 mod
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Like Noah said, get an HEI, you will have less problems and I bet you will not have that problem anymore.
    Here you can get it for under $100.
    No Idea how much in Norway though. /forums/images/graemlins/grin.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Sounds to me that you are either experiencing point bounce or valve float. Valve float usually does not occur until around 5000 or 5500 RPM's. It would be my best guess that you have a bad set of points. Like others have said, your best bet is to install either a HEI distributor or an aftermarket electronic of some kind. You also could install a pertronics magnetic pick-up into your existing distributor which will eliminate your points.
  9. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    ok i think i am going to get a HEI.
    but it cost around $200 in norway /forums/images/graemlins/smile.gif
    but what kind of spark plugs shoud i go for when i install the HEI?
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Same plugs
    /forums/images/graemlins/thumb.gif
  11. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    it was not the same plugs! difrent gap... made the enegine not run clean!
