spark plugs
Discussion in 'The Garage' started by 4whler, Jan 4, 2004.
  1. 4whler
    4whler Registered Member
    Nov 6, 2003
    12
    Middle of TX.
    Just got back from parts store with plugs and wires and they gave me r43ts,always used 45ts. Are these ok with a 350 and holley pro inj. Did a search all I can find is the gap.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I you have always used something else and they work fine, go back and trade them....
    Learn how to read the plugs, and adjust the heat range a bit if necessary....
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The number in the AC plug designation is the heat range. An R43TS is a colder plug than a R45TS. Do as SUBFAN suggested and learn how to read the plugs. If the engine is stock, then use the factory recommended plug and go from there.
    FYI....here is a definition of Heat Range
    "Heat range refers to the spark plug's ability to transfer heat from the tip of the insulator into the cylinder head. In order for a spark plug to perform satisfactorily for more than a few miles, it must be of the proper heat range. If a plug is too hot, it will cause pre-ignition, and can burn the center electrode completely away. If a plug is too cold, it will have a tendancy to foul and misfire, reducing horsepower" (Small Block Chevy Performance)
    My old 350 liked R43TS's but my 388 with the same heads, likes the R44TS's. /forums/images/graemlins/thumb.gif
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i had to run r46ts in my old engine because# 8 oil fouled so bad.and i would still have to swap it with the #1 cylinder every four months. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. 4whler
    Nov 6, 2003
    12
    Middle of TX.
    Thanks for the FYI learn something new every year.
  6. dyeager535
    26,979
    Actually, to be nitpicky, the last numner is the heat range, the first number is thread size. (4=14MM)
    But for the heads we deal with typically, the 4 is a constant anyways.
    (R=Resistor, 4=thread size, 5=heat range, T=tapered seat, S=Extended Tip)
