spark problem
Discussion in 'The Garage' started by 2High4U, Oct 26, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    im getting spark but its kind of erratic and missing the timing is set right and it wasnt that long ago that i replaced the cap rotor wires and coil it was running ok for a while and then for the past week it was running like this any idea solutions.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Ignition module could be going bed. I just went through all that crap on my truck and my neighbors. Mine turned out to be the distributor main shaft, his was the pick-up coil, EST, and the reluctor was also broke????
    What a week:doah:
  3. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    just what I need more possibilities.. I guess ill have to get my nickels and dimes and try part by part until it stops :mad: this is a usual occurance for me.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Have you taken the cap off to look at it ? I know there was some rain back east recently .
  5. readymix
    May 30, 2004
    6,706
    26
    are your injectors firing?
  6. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    its carbed we did have rain and i didnt pull the cap yet i will do that right now let you know what i find out in about 20 min its running just missing really bad i checked the spark and it was sparking just not as much as it should
  7. readymix
    May 30, 2004
    6,706
    26
    OH, Should have checked:doah:
    Cap, Rotor, Wires, Coil or wiring in general
  8. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    well i took the cap off and looked at everything no moisture and everything looks to be ok it is missing very badly up until this moning it was running ok i think that the whole motor is junking out i have had problems with it ever since i got it everything was fixable until now the cam was starting to get flat and i have always had timing issues im guessing because of the cam :(
    i dont want to say how many times i redropped the distributor when i first got it thinking it was off a tooth
