Spark Wires & Dist Q...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevyCaGal, Jul 10, 2001.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Ok, I did a search and got not exactly what I want... it's getting dark and I need to get my spark plug wires on asap.... what is the order on the dist cap.... that is they go on number wise.... (from bottom left) is it, 8, 4, 3, 6, 5, 7, 2, 1? I dunno if this right but i pulled this from somewhere..... and on the engine... the number order on the spark plugs? If I was facing the front of the Blazer... left side (pass side) and right side (drivers side).... thanks so much.... I'm saving money by doing work myself... and I am actually doing it and not messing up too badly lol! [​IMG]
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    OK - as you look at it, the plugs are
    8 7
    6 5
    4 3
    2 1
    fan
    The firing order is 1-8-4-3-6-5-7-2, with #1 being on the bottom left as you look straight down at it.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The firing order is 1 8 4 3 6 5 7 2, the number one wire goes on the 2nd post to the left of the "bridge" that covers your HEI wires that go into the dist. body. Hope that made sense.
    "My blazer may be slow, but it goes faster at higher speeds"
    <A target="_blank" HREF=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</A>
    Jim
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Unfortunately you don't know where the #1 is, could be anywhere depending on who put the distributor in. GM says it's supposed to be directly to the left of the place where you put the wires, then go around in a clockwise fashion in the above order.
    Tim
  5. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Not true 84_Chevy_K10, all she has to do is pull the dist cap, pull the #1 plug, and then have someone jump the starter until air pushes her finger out of the #1 spark plug hole, then she'll be at TDC on the #1 cylinder and the rotor should be pointing to that cylinder. Easy as cake.
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
