Sparkin Plug Debate
Discussion in 'The Garage' started by Cricket, Dec 27, 2004.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    After the overwhelming ass-kickin I took on Bosch spark plugs I hauled by bruised carcass out this morning and picked up AC Delcos. There are too many people here running AC's with good results that can't be ignored. I HAVE SEEN THE LIGHT! That's right brothers - I have come to CK5 Jesus, Hellalujah.
    If anyone else is running an MSD ignition, what are you gapping the AC Delco sparkin plugs at on a 350 cheby? Looks like the recommendation is .050 or 5 over the stock .045. Anyone running wider than that? Your fellow heathen is all ears and salt packed scars.
    SMITE ME - OH MIGHTY SMITERS
    :ears:
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    I've always run .050 with my MSD stuff my 454, works real good and keeps the plugs clean.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The best application i have found for Bosch Platinums is Fishing weights. I like to use old crappy plugs for Ocean fishing. They cast well and carry a good distance. they are heavy enough to keep your bait down in a small current. If you get snagged loosing one is no big deal.
    Oh. I run .050 in my AC delcos too. 350 cid dont have MSD I have DUI.
  4. chevyjsport
    chevyjsport Newbie
    Dec 26, 2004
    3
    north carolina
    my bosch work awesome with my msd
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When I ran MSD ignition I ran Champion Truck Plugs gapped to .057. With Delco's I would run .055.
    Harley
  6. dyeager535
    26,982
    191
    GM ran .080" gap on the same ignition stuff that they ran at .035", and it works the same either way.
    I tried them gapped .035" vs .060", and there was no difference in mileage or (perceived) performance at the two extremes.
    In other words, you won't notice any difference. Stock HEI alone will jump any gap you are going to run in a street engine, so just go with what is recommended, or play around on your own.
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I run .065 on my 496 w/ my MSD on AC-Delco R45TS
  8. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    amen brother you have hit rock bottom and come out
    like thay say drive american buy american drive jap or euro be ready to be cruched by american v-8 . as tim alen would say ug ug ug
  9. chevyjsport
    chevyjsport Newbie
    Dec 26, 2004
    3
    north carolina
    yep
    i run at 45 never had any problems no need in playin with fire you could possible get burned
  10. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    MSD recommends between 35 and 65 I've been playing around with gap on my camaro and 45-50 seems ok sofar
  11. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    I'm running a MSD dist., coil and 6A with Accel wires and gapped mine at .60 with no problems..
  12. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    From my experience Bosch plugs used to run well in GMs, however they are total junk now, ACDelcos or NGKs seem to work well in GM vehicles.
  13. chevyjsport
    chevyjsport Newbie
    Dec 26, 2004
    3
    north carolina
    hmmm
    i guess it all just depends im runnin a 6al with 8.5 mm wires and blaster coil on those bosch gapped at 45 and they run great pull em out and clean as can be
  14. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I think the jist of the whole thing was performance over time. The main issue as outlined by Tim amongst others was the return rate and dissatisfaction with the plug over a few weeks to a few months. I know I was having a harder time finding the Bosch and it makes sense that parts stores would quit selling them if the product quality was declining.
    I have swapped out to Delcos and do not see any short term performance improvement but the test will be over the next several months. You certainly have to take into account the overwhelming response to the question. When 98% say Delco and 2% say Bosch or Splitfire there is an obvious trend there. Certainly one worth exploring further.
    It could very well be that the MSD is covering up a problem that would occur with a regular HEI - I don't know and that is pure speculation.
    If you like Bosch stick with it. There are times when you have to go with your own feeling over those of the majority. I simply wanted to put it to the test and am doing so. We'll see what happens in the next 6 months.
  15. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Son of a B%6#&. I knew it. We have a 94' vette, and recently replaced the stock AC Delcos with plat 2's, and I noticed a hefty loss in performance, but a friend said it was due to mistimings? I though no.... I was right.
