spatter problem
Discussion in 'The Garage' started by 87k10, Nov 17, 2005.
  1. 87k10
    87k10 Registered Member
    Sep 1, 2005
    31
    colorado
    i have had my welder for about 4 months now and im using it quite a bit but still get the spatter around my welds. i also tried the anti-spatter spray and it helps but something is off. is it my wire speed? the surfaces are ground down to bare metal and clean. what else can cause this? i have welded with gas at at a friends shop and it wasnt as bad but he adjusted everything as far as wire speed, arc volts ect. what am i doing wrong? :confused:
  2. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    Are you using flux core wire? That stuff always brings the splatter.
  3. 87k10
    Sep 1, 2005
    31
    colorado
    yes its flux core
  4. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Well that's your problem. It does this by design, well side effect. Switch to solid core wire and use shielding gas, if your welder has provisions for this.
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Thats why a couple months after I got my welder I switched it to MIG. Was the Lincoln Weld Pack 100 I think. I use CO2 cuz a buddy got me a bottle and its also what I use for the keg. So if I ran out on the keg I know I'm still good to go!! :bow:
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    :haha: :haha: :haha: :haha: :haha: :haha: :haha:
