Spay in bedliner in the cab
Discussion in 'The Garage' started by AnthonyG, Mar 16, 2003.
  1. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I have carpet in the cab right now and i want to get rid of it and just bedline it. has anyone done this? how did it turn out? Is it worth the money saved to do it your self or should i just pay someone to do it for me?
    If you have done this do you have pics?
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I think theres been like 100 of these posts... but i used duplicolor, and really like it, i did my entire front and rear floor. And I liked it so much i kept the back seat and rear carpet out for good...
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I haven't done it yet but I will someday when everything else gets done and when I do I plan on using Durabak I feel it will last longer than than the other DIY stuff and will be somewhat cheeper than Rino or LineX
    Eric
  4. VirginiaBulldog
    VirginiaBulldog Registered Member
    Mar 15, 2003
    74
    Virginia Beach, VA
    yep hundreds of posts on this. when you pull the carpet out and are trying to get that gunk off the floor, works well to heat it up and scrape it off.
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I used carb cleaner and paint thinner , and then wiped it down with a towl. I had to grind of rust and patch a few holes. But it was all worth it.
  6. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    the entire interior of my rig is herculined. Saved me lots of $ and its super easy to clean and repair if I damage it. If I was rich, I would have got it line-X'ed as it is a) tougher and b) has better sound deadening qualities. It probably makes the body slightly more rigid as well if its applied in the 1/4" thickness.
    at any rate, you can get herculiner for $70-ish a gallon if you wait for it to go on sale (napa has it on sale once a year or so). I have used about 2 gallons on my rig. pics in webshots....
    j
  7. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Do a search if you want more info. Short: Rhino, liked it.
  8. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    my rig was brown and tan two tone when i bought it. got it painted black, just the outside, so i bought some cheap spray on stuff, and taped off what was still brown in the door seals, sprayed them, and did the inside of the tailgate as well... REALLY like it /forums/images/graemlins/smirk.gif
  9. BowtieGuy3
    BowtieGuy3 Guest
    I once met a guy at a car show who had the entire outside of his '40 Olds sprayed with an orange Rhino lining. Looked pretty damn cool if ya ask me....
