speaker covers
Discussion in 'Audio' started by hoppy, Mar 23, 2003.
  1. hoppy
    hoppy Registered Member
    Aug 20, 2002
    56
    how do you remove the speaker covers on the dash of a 1994 fullsize blazer? do they just pop off? also what can prevent rattles coming from the covers?
  2. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    They are held on with clips. Take a small screwdriver or something and gently pry them up. Be careful that you don't break the plastic. You may have to use more than one to pry and work around. As for the rattling noise, i put some of those little stick on felt pads on mine where they might rub. Also make sure your speakers are tightened down good, it might be those vibrating and not the covers.
  3. hoppy
    Aug 20, 2002
    56
    thanks dale fan ill try that
