speaker suggestions
Discussion in 'The Garage' started by bigbadchev84, Jan 12, 2007.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i am looking for a set of 6x9s and 6.5s for my car i dont want high-end, just some good sounding economy ones that can handle 200-300 watts. thanks guys
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    bang for the buck would be Soundstream . Come with cool spiders in the center as grilles . I dunno about putting that many watts into anything .
    I like Memphis too , after a friend told me about them . Ebay is a good source for those cheaper than the stores .
    If you want some decent bass you need subs .
    If you want clean all around sound , albeit with only as much bass as a smaller speaker makes , you won't need 200 watts per speaker . A smaller 4 channel amp would be fine , or deck power since you sound on a budget .
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Crutchfield
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    I already have all the amps- 1200w mtx for the subs and a 520w for the mids, so i am wanting just some decent clean sounding speakers for the mid-highs, i use a crossover to filter out the lows going to them anyway, sorry for not specifying before, also i was wanting to spend no more than $60 a pair, thanks
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Soundstream XTS 6x9's fit the power and money requirements . I can vouch they sound nice . Chronic Car Audio turned me on to those . I run this brand for my front stage .
  6. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    is that RMS or is that peak output on ur amps??
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I would only put that kind of power into some Boston Acoustic Pros.$600.00
    Any set of speakers for under a hundred bucks should only have around 40 watts max going to them, when you are talking 6.5". 6x9s can get away with a little more. Alot of that even depends on the signal source, output voltage of the RCA connections and quality of the amp.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I highly doubt his 520w amp is going to hit that high rating much of the time anyway , and the rating is total peak for all channels anyway . If its a 2 channel its only 260 watts peak at clipping ( if really that in reality anyway ) . Who really runs their amps that hard in a real world driven truck on a budget .
    The speakers I mentioned were 80 watts RMS , 200 peak each . They are also 92db sensitivity <------- he will not need to crank em up to be loud anyway . So his amp is overkill , and doesn't even need to be cranked loud enough to hurt the speakers .
  9. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    though ratings more than likely are peak out put. also ur smaller amp how many channels is it?
  10. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    they are both 2 channel amps, the 1200w is an mtx mono amp the other im not sure, but it is what i have and prefer to run my speakers off amps anyway. this is going into my car by the way.
  11. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    I like Pioneer. Just installed a CD player, 5.25"s in the front, 6"x9"s in the rear, and a single 12" sub in my rig. Sounds good and I didn't drop too much coin. Pioneer is all over Ebay but sometimes you can get their stuff even cheaper at Walmart.
  12. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    a good set of 2 ways that will handle 2-300 watts is gonna set you back around 100$. i would spend the extra and get a quality set, why buy something you plan to replace later???
