speakers cutting in and out again
Discussion in 'Audio' started by balzackks84, Nov 26, 2002.
  1. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Ok a while back i posted a problem with the speakers cutting out. It seemed as tho it was my drivers front was shorting everything out. (when i unpluged it the system was fine) So i put in a set of infiniti refrence series.
    Well its doing it again but a little different. It just cuts in and out really fast when the truck vibrates or hits a bump. Any suggestions as to what it could be. Ive checked all the wiring and it seems fine.
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Just cuz you checked the wiring and it seems fine doesn't mean it is. I'd replace the wiring to that speaker and see what it does. You might have something going bad in the wire, like somehow moisture got in there. Maybe a small slice somewhere you missed or maybe the wire isn't big enough to handle the power...
  3. AudioMaster
    AudioMaster Registered Member
    Jul 26, 2002
    28
    Southern Utah
    Sounds like just a loose connection. The best remedy is to run new wires. If you aren't comfortable doing that then just check all your connections to see if they are loose or dirty.
    ~AM
  4. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    make sure all the speaker wire are not grounding cause mine did this and the wires were grounding on the dash
    /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
