speakers
Discussion in 'The Garage' started by joshkbomb, May 2, 2004.
  1. joshkbomb
    joshkbomb 1/2 ton status
    Dec 18, 2003
    187
    Lafayette, CO
    I'm thinking about new speakers and I know I'm getting 6X9's installed in the rear, but what about the front? The guy at Quality Auto Sound said I could install 6" speakers in the door, but I don't know if I could bring myself to cut holes in them not to mention the fact that they would then be down near the bottom of the door. Is it possible to fit 5-6" speakers in the dash in place of the 3" ones? If not, I think I'm probably going get more 3" speakers. Also, should I replace all the speaker wire?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    This probley should be in the audio forum, but I recomend Q-forms kick panels. They aim the speakers better. Clicky
  3. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I always run monster cable when I get a vehicle. To me its worth it. To fit the 6" speakers though I'm pretty sure you will have to /forums/images/graemlins/hack.gif to get them in.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you will have to hack to get them in, as most trucks didnt come with speakers in the doors. i had a set of 6.5" in my 82. they worked ok, but the sound imagine was nothing compared to my 86 and its stock 3.5" speakers in the dash. i happen to have an extra set of 3.5" dash brackets.
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have 6" in the doors and 6x9's infront and behind the rear seat...
  6. joshkbomb
    Dec 18, 2003
    187
    Lafayette, CO
    It looks like I'm sticking with the 3.5" in the front, though I went with Boston Acoustics. In the rear, for only 30 bucks more, instead of installing the 6X9's in the panels I'm getting two boxes which I can put anywhere. This is probably better, because I can have one sitting in front of the spare and then unplug and take them both out when I need to haul something. Or maybe put them both up on the wheel wells.
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    get some high quality front speakers it makes a differance like the infenity 3.5's
  8. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    not to hijack. but how do you replace the font speakers? I haven't really checked (dash cover) were to to take them off.
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    pull the dash pull the dash pad
    take the bracket with and speaker out as 1 peice(2 screws in each)
    take the speaker out of the bracket
    replace speaker
    re install the bracket and speaker
    re install the dash pad
    When I got my speakers I got them from crutchfeild and came with new brackets that looked pretty strong but they dident fit as well as the stockers so I re-used my old ones
  10. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    wow that's alot of work to repalce those speakers...
    thanks
  11. Storm Trooper
    Nov 24, 2000
    4,640
    I know it's tough to cut the doors but I did and my system rocks! 3.5" speakers just don't cut it. If you want to see what I installed click HERE
    The reciever is no longer made but if someone had it and I needed another one, I'd grab it. You can wheel, jump or even beat on the dash and it won't skip. I think I can just about blow my ear drum out if I want to. The 12" sub only has the problem of shaking everything that is loose in my truck but such is life. I can just turn it down /forums/images/graemlins/peace.gif
  12. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    not really it took me about 15-20min but I wasgoing SLOW
  13. 1989blazer
    1989blazer Registered Member
    Jan 7, 2004
    35
    Bay Area, CA
    I put 6x9's on 1.5" standoffs on my doors in the bottom front corners. Some hacking was required. I just cut enough to clear the magnets. Be careful to not cut the anchor for the window lift mechanism. Had I a larger budget, I'd put some mid-range and tweeter speakers on the doors that wouldn't require cutting and then build bass cabinets into the sides either behind the rear seat or perhaps in front. It would depend upon how many people were in the truck on average. Probably 8's or 10's. Then if I was still on a limited budget, I'd do passive cross overs. otherwise, active and lots of amps. I have 6x9's in back as well, but mounted in that crap cardboard. When I have some time, I'll build wood enclosures behind the side panels. Having built a lot of different speaker enclosures (I'm an EE), I've found that that getting the enclosure right is the best bang for the buck. You can wire passive cross overs yourself, it's pretty easy. Even hard-wired actives aren't that hard. Just gotta follow directions. While I haven't looked, there's probably lots of stuff on the net on how to design and build cross overs.
