speakers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Oblin Goblin, Oct 11, 2000.
  1. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    What are the sizes of the speakers in an '84 Blazer. I think the 2 corner speakers in the dash are 3.5" and the ones in the very back are 4x10 but I have no idea whats in the middle of the dash. I'm guessing a 4x6 or 2 more 3.5's.
  2. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    I don't there's anything in the middle unless your truck came equipped with the lowest line factory radio. Mine came with a digital display auto rev. am/fm cassette ( crap ) and used 4 spkrs , 2 in the dash corners and 2 in the rear corners ( also crap ). If you have a front center speaker, you normally don't get the others. ( mono )
    Denis -MIDCAN k5 " DIG A HOLE!!!"
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    If it did come with a middle front speaker, i believe it is a 4x6.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    It is a 4x6 most likely. That is what i have seen people put in there dash but hooked it up to their cb. It is used in that case as an external speaker. Pretty nifty setup. I would suggest you stick to the 3.5s and 4x10 or else you will have to cut door panel for 6.5s. That is what i did. Dont like 3.5s too small. I have also seen 6x9s cut into the rear panel on either side of the rear seat.
    Later
    Have you driven OVER a Ford lately?
  5. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    I forget where I saw them, but someone has a cool setup that they took a 4x6 frame and mounted 2 high quality 3.5"s in the frame of a 4x6 so that you could essentially have 4 3.5" speakers in the dash, and if they are good enough wire them in parallel down to 2 ohms, they would have to be high quality speakers. Thats what I am going to do, since I cant remember where I saw them I will just make my own.
    If it aint a Chevy don't raise it up!
  6. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    I'm making new panels for the rear and will be putting two 6x9 in the very back, and either two more 6x9's or maybe 4-6 inchers by the rear bench kind of down by the feet. with possibly a 250 watt amp...or maybe something stronger..?? dont know yet
