Speaking of hot cams
Discussion in 'The Garage' started by dremu, Jan 17, 2007.
  1. dremu
    Feb 27, 2000
    15,958
    450
    East of San Francisco
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Looks like an in-between cam to me. May be the best of both worlds. I assume this is for the 454?
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You got a new motor? For your Crew?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It doesn't look like it's designed for towing. I found this on their website:
    [FONT=Arial, Helvetica][FONT=Arial, Helvetica]"Best with improved intake manifold, needs headers and 3.55-3.90 gears and 2000+ stall." [/FONT][/FONT][FONT=Arial, Helvetica][FONT=Arial, Helvetica]It's not recommended for use with the stock torque convertor and doesn't start building power until 1,600 RPM. :-( Take a look at their cam info for big blocks here.
    That engine will be a blast to drive once the cam hits the sweet spot, but it probably won't be the best choice for towing heavy loads. Give the tech line a call at Comp Cams and talk with them about your truck and what you want to do with it. They can then recommend a cam that meets your needs. It's WAY easier to swap the cam now, before the engine is in the truck. :cool1:
    [/FONT]
    [/FONT]
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Not the cam you want for towing. For a towing application comp cams 11-231-3 would be best. What year is the rig it's going into? If it needs to be smog friendly then you need to watch out what cam you choose.
  6. dremu
    Feb 27, 2000
    15,958
    450
    '74, so thankfully, no no smog :D
    Yep, it's for the sixpack. Dangit, I was hoping to have this truck together this month =)) ... this stuff never ends!
    -- A
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmm...
    Where ya getting the motor from? iceman?
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yep :D
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Will that cam work on my 396/402 BBC?
    It's going in a 70 2wd pickup that will be for cruising and show.
    If so then I will take it Aaron and I will get you the cam of choice for the setup you need.
    :D
  11. dremu
    Feb 27, 2000
    15,958
    450
    Sound familiar? :haha:
    Iceman, I'll pm ya.
    -- A
  12. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    that cam's a little big for a truck imho, especially if it's not like 9.5-10:1 CR. Power brakes may even be effected. I'd swap something a little milder in unless you really need the horsepower.
  13. dremu
    Feb 27, 2000
    15,958
    450
    Power brakes? You mean *vacuum* boost? (The truck has hydroboost.)
    But yeah, it sounds like a great street, grumbly-exhaust, tire-chewin' monster ... which is not me.
    And thanks Iceman, I'm looking for to my package from Summit, and your brother should enjoy this cam :D
    -- A
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Ha! Thats pretty cool. Atleast that motor is going to someone who will approciate it. It was installed in my '83 K20...former 6.2 truck with a 465. It also had hydroboost, and no torque converter worries. It was fuuun to daily drive it. No problems shredding the carp out of 35" BFG AT's even with 3.73 gears. I had to install different valve springs for that cam too....so if you switch it out, you'll mos likely need new springs. The timing set and lifters are also new comp cams stuff.
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I have the desktop dyno screenshots on my other computer. Soon as its fixed, I can send them to you.:D
  16. dremu
    Feb 27, 2000
    15,958
    450
    Well, my sixpack is not so likely to chirp the tires :haha:
    New springs duly noted.
    -- A
